For Sale GVP I/O Extender (A2000/3000 (?4000?) Zorro II)
Bifford
Rating - 0%
0   0   0
Wiltshire
I've had this knocking about for goodness knows how many years. I thought that it was last used when my A4000 was still in its desktop case which has to be a good 15 years or so, but reading the instruction manual it suggests A2000/3000 only use so maybe I've never used it? The brown paper I have used to protect the rear solder points suggests otherwise.
I have no use for it. I can not guarantee that it works, but I see no reason why it wouldn't as it has been stored carefully. [If I'm able to test it, I will]
Info from the Amiga Big Book of Hardware: https://bigbookofamigahardware.com/bboah/product.aspx?id=601
GVP I/O Extender for the A2000/3000/4000 Zorro II slot.
Serial + Parallel interface.
One DB25 parallel port; two buffered DB9 serial ports.
1-614400bps serial transfer speed.
ST16C552 interface chip with 16 byte buffer.
MIDI sub-port for MIDI expansion box - 1 in, 3 out, 1 through.
Expansion port for RS422 or RS232 kit.
Parallel port set to Amiga or IBM compatible.
I will look to see if I have the software disk - no guarantee I have one. >>> DMS files download available from http://l8r.net/install/eth.ser.html
The instruction manual is available at the above link.
This item is location in Wiltshire, UK. Postage costs would need to be on the buyer if overseas. I would need to package it up to see what the UK cost would be.
Research suggests £125 is a valid price.
Regards,
Sam / Bifford
