Wanted GVP TBC PLUS Octopus cable or simple version of it.
miggygossip
Tasmania
Looking for an input/output cable for my GVP TBC Plus card. The original octopus cable or a basic custom cable. AV in- out- etc.
TBC Plus Technical Specifications
Host Commodore Amiga 2000, 3000(T) and 4000
Communication and frame grabber transfer through Zorro bus expansion slot
Inputs Note: The video inputs may come from a variety of video sources (i.e. VCR/VTR, laserdisk, still camera, camcorder, studio feed, etc.) with different levels of input quality and in a variety of signal formats.
Three software switchable CVBS and Y/C (intermixed) Channels w/AGC:
Channel #1:
Composite Video Port #1 BNC jack 1 V p-p / 75 W ohm
or separate Y2 input port in Y/C mode 1 V p-p / 75 W ohm
Channel #2:
Composite Video Port #2 BNC jack 1 V p-p / 75 W ohm
or separate C2 (burst) input port in Y/C mode 286 mV-300mV p-p / 75 W ohm
Channel #3:
Y/C Video Port #1 4-pin mini-DIN (S-VHS) compatible connector
Note: The Y/C inputs (#1 and #2) have the following levels:
NTSC - Y @ 1 V p-p / 75 W ohm, C (burst) @ 286 mV p-p / 75 W ohm
PAL - Y @ 1 V p-p / 75 W ohm, C (burst) @ 300 mV p-p / 75 W ohm
One Black-Burst (Reference/Genlock) Input Channel:
BBI Input BNC jack BBI @ 440 mV p-p to 4V p-p / 75 W ohm or Hi-Z
Note: When the BBI signal is not present the TBCPlus locks the color-burst and sync timing to the internal Broadcast-quality digital sync generator for accurate color framing. When the black burst signal is present, the encoder will lock both the SC-H phase and sync timing to the broadcast-quality external reference for output timing. If time-code or other vertical interval information is present on the BBI signal, the TBCPlus can output this information on the CVBS output as well if desired. This signal can also be keyed over the selected input channel or frame-buffer contents for special effects via the EXTKEY input channel.
One External Key Input Channel:
EXTKEY Input BNC jack TTL Level - Programmable polarity
One SMPTE (LTC) Audio-Level Input Channel (if SMPTE option is installed):
SMPTE Input RCA jack Audio Level
Note: This input channel can receive LTC data in forward or backward direction at a rate from 1/30th to 80X nominal frame rates in SMPTE and EBU formats.
Outputs One Composite Video Genlocked Output:
CVBS BNC Jack 1 V p-p / 75 W ohm
One Separate Y/C Genlocked Output Channel:
S-Video Compatible Output, 4 pin mini-DIN jack
NTSC Y/C 3.58 - Y @ 1 V p-p / 75 W ohm, C (burst) @ 286 mV p-p / 75 W ohm
PAL Y/C 4.43 - Y @ 1 V p-p / 75 W ohm, C (burst) @ 300 mV p-p / 75 W ohm
One Advance-Sync Output:
ADSYN BNC jack 4 V p-p or 2 V p-p / 75 W ohm
Advance Composite Sync output signal 4.1mS ahead of CVBS output.
One SMPTE (LTC) Output Channel (if SMPTE option is installed):
SMPTE Output RCA jack Two modes: Analog Audio Level or Digital level
Analog Output: Audio-Line level with programmable gain from -24dB to +9dB
Digital Output: TTL level
Thanks.
