Ham Video
Nobby_UK
Liverpool, Lancs
Been trying this :
http://majsta.com/modules.php?name=News&file=article&sid=9
But the prog (AVI4HV.EXE) will not accept my audio files
What gives ?
General
Complete name : C:\AVI4HV\Kylie.wav
Format : Wave
File size : 2.02 MiB
Duration : 1mn 36s
Overall bit rate mode : Constant
Overall bit rate : 176 Kbps
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Unsigned
Codec ID : 1
Duration : 1mn 36s
Bit rate mode : Constant
Bit rate : 176.4 Kbps
Channel(s) : 2 channels
Sampling rate : 11.025 KHz
Bit depth : 8 bits
Stream size : 2.02 MiB (100%)
dw0ntU5m3
US
Michigan
I haven't done this, but when it has the ? mark after it touches the video it's asking for the audio file name which you type in Kylie.wav. This is not apparent in your screenshot. Just a guess.
Nobby_UK
Liverpool, Lancs
You were correct :D
I just assumed it would expect the audio to have the same name :roll:
Just did one at 11025 no-dither and another @ 22050 with dither
Big Buck Bunny Next !
:D (y)
#EDIT#
Tried a 24 bit version of Big Buck Bunny with Avi4AGA
seemed to be working but did not complete
Possibly because the AVI was 2.25 GB (2,419,439,532 bytes)
Will have to try a 24 bit version of Kylie...
Nobby_UK
Liverpool, Lancs
Well they sort of work :LOL: But Slowly
I should have changed the frame rate (to 15 fps)
My 600 playing one (see attached)
[video]http://vidmg.photobucket.com/albums/v211/Nobby_UK/STUFF/Kylie_zpsnkzolyhe.mp4[/video]
It looks better on a TFT than a TV to me.
dw0ntU5m3
US
Michigan
Great, that's... uh.. um. Wouldn't it just be easier to use frogger or riva to play AVI or MPG directly for your Amiga pron needs? On second thought don't answer that.
Nobby_UK
Liverpool, Lancs
Avi would have to be converted to CinePak (which I did for Wrecking Ball ;))
I think there is 3ivX/DivX/XviD for the Amiga but PPC only ?
MPG (VCD) is prob... easiest all round, but still requires a fast CPU/GPU.
But this is supposed to allow unaccelerated Amigas Video...
