hard disk problem
Commodoriano
Spain
i have a A4000T with GVP 060 card. i was installing diropus when the machine hang up with a guru meditation. When i boot , requester tell me that the work partition has a checksum error on disk block 1025010.
some solution? the hard disk is damage?
thanks
Justin
thanks
unlikely but have you checked your PSU?
Justin
how much space did you have on the work partition?
i have had 3 amigas now where what seemed to be hard drive errors were actually caused by dying PSU's
have you installed this version of diropus before?
Commodoriano
Spain
the work partition have 940mb space and the workbench tell me the partition is full. Appears a requester with message work partition has a checksum error on disk block 1025010.
if i format the disk ?
Justin
if you format the disk i would still be worried about your PSU until you get it checked
Commodoriano
Spain
there are some options for format:
- put traschan
- Fast file system
- international mode
- directory cache.
davideo
I look like Gizmo
Staff member
Administrator
Staff Moderator
Treasurer
Boston, Lincs
This is confusing.
That can be the problem with international boards :oops:
I think Juvvie's doing extremely well (y)
And as for the English language there's nothing more confusing with its there, their, where, we're etc.
Dave G :cool:
Justin
it is confusing but patience is the key here, it's just a little language barrier.
@landoq, can you test your PSU? if it's ok then we can try something else, but if the PSU is faultly formatting your drive will not fix the problem
puede probar la fuente de alimentación? si está bien, entonces podemos intentar otra cosa, pero si la fuente de alimentación es faultly formatear el disco no se solucionará el problema
i hope google translate isn't telling him to do something rude
amigaman2000
Amiga Forever
Spain
Pontevedra
Hi landoq
Perhaps you have a problem with the hard disk, is a new one or is some years old? You can format it again and copy some files to and from hard disk if tha hard disk fail again it's probably because a faulty hard disk, try another one and test it.
And if a friend can test the power supply will be great.
Regards
Si necesitas explicaciones en español mándane un privado para no "ensuciar" el foro.
