Hello from Holland!
Pegasosuser
The Netherlands
Utrecht, Veenendaal
Introduce:
Hello, I'm Cor.
What it started with: Commodore 64 I bought this computer somewhere between 1982-1985. I'm going to look at the type plate today or tomorrow to see what the year of manufacture is if it says on it. I did a lot of things with this Commodore 64, including gaming, entered basic lists from magazines until you had a working program or not!,
This was a really fun time and I made a lot of friends, who I still sometimes speak to via Facebook! they too have switched to the Commodore AMIGA or otherwise.
Then came the Commodore AMIGA 500, which I did a lot of things with (I still have it in my possession!) I haven't used it for a long time, but I definitely want to use it again!
Later the Commodore AMIGA 1200 also came along with it, it did a lot of work and it is still in my possession and I want to use it again soon.
Then came the PegasosII system from BPlan, which I was able to purchase via a private PC project at my work, which I had not used for a long time, I connected it again last week and turned it on and it works! the date is still correct except the time was slightly off, which I have to reset.
On the PegasosII I have a G4 with 1 Gb of memory and it now has MorphOS 2.5 (Registered), which I will update next week with MorphOS 3.18.
Later I got another PC and later what I now work with is a Laptop with Windows 11. I have to say that Windows doesn't do much for me, but I do use it a lot, but my heart lies with the Commodore 64, AMIGA 500 and the AMIGA 1200.
That's it so far, I will add some more later.
Greetings Cor.
Voor de nederlandse gebruikers:
Even voorstellen:
Hallo Ik ben Cor.
Waar het mee begon: Commodore 64 deze computer heb ik gekocht ergens tussen 1982-1985 Ik ga het typeplaatje vandaag of morgen bekijken wat het bouwjaar is als het erop staat, Met deze Commodore 64 Heel veel dingen gedaan waaronder gamen basic lijsten uit tijdschriften ingevoerd totdat je een werkend programma had of niet!,
Dit was een ontzettend leuke tijd veel vrienden opgedaan die spreek ik nu soms nog via het faceboek! ook zij zijn overgegaan naar de Commodore AMIGA of anders.
toen kwam de Commodore AMIGA 500 waar ik heel veel dingen mee gedaan hebt (deze heb ik nog in mijn bezit!) lang niet meer gebruikt maar wil deze zeker weer eens gaan gebruiken!
Later kwam de Commodore AMIGA 1200 ook met deze ontzettend veel mee gedaan ook deze is nog in mijn bezit wil deze binnenkort ook weer eens gaan gebruiken.
Toen kwam de PegasosII system van BPlan deze kon ik via een PC prive project op mijn werk nieuw aanschaven deze had ik ook lang niet meer gebruikt, deze heb ik afgelopen week weer eens aangesloten en aangezet en het werkt! de datum is nog steeds correct behalve de tijd wijkte wat af dat moet ik opnieuw instellen.
Op de PegasosII heb ik een G4 met 1 Gb geheugen er staat nu MorphOS 2.5 op (Geregistreerd) deze ga ik aan komende week updaten met MorphOS 3.18.
Later heb ik nog een PC en later waar ik nu mee werkt een Laptop met Windows 11 hierbij moet ik zeggen dat windows mij weinig doet doe er wel veel mee maar mijn hart ligt toch wel bij de Commodore 64, AMIGA 500 en de AMIGA 1200 .
Dit was het tot zover later zal ik nog wat aanvullingen doen.
Groetjes Cor.
