Help needed - AMIGA 1500 powers up but black screen
dj.echo
EASTSUSSEX
an AMIGA 1500 powers up but black screen any one help plz(y)
davideo
I look like Gizmo
Staff member
Administrator
Staff Moderator
Treasurer
Boston, Lincs
@dj.echo
I've changed your thread title to something a little bit more meaningful.
Hopefully you'll get the help you're looking for.
Dave G :cool:
tokyoracer
(Not actually from Tokyo).
Ok first up is there any flicks of the screen as it boots up? Also if you can open the cover up and take some pictures that would help us alot to try and solve your proplem.
Hopefully it may be a simple case of re-seating a chip if it's a hardware fault. However when you do open it up check if there is a battery and what state it is in as these can leak badly over time creating sometimes un-repairable damage.
dj.echo
EASTSUSSEX
thanks
thanks
will get some pic`s up asap(y)
Do you have a SCSI or IDE controller with an HD hooked in? Does the HD activity LED on the front of the case lit?
The HD activity LED is lit all the time? If so, you have a non-validated partition and the Amiga will refuse to boot until it conclude the re-validation process. Keep it on until the process end, that might be for two entire hours to up to a week, pending the partition size!
Also move the tick source jumper J300 (or J102 if the mobo is 4.x or EARLIER) from 1-2 position (tick from power supply) to video source (2-3). That is to check if the power supply is feeding the Amiga with the tick signal, if this signal is not present (and A2000 PSU is known for dying without a reason). If the Amiga boots again, you'll know why.
Tomse
RISK is good
Denmark
Copenhagen
as rkauer said.. are there any drive activity ?
can you hear the ticks from the floppy drive? does it register a floppy when you insert it (small activity on the floppy LED) ? and lastly does it boot the floppy if it's bootable ?
what rev is the motherboard ?
have you checked if it has leaked battery acid, are the caps ok ?
dj.echo
EASTSUSSEX
hi all
hi all
taken the hole a1500 apart i can see some damage near the battery the rest looks ok power light comes on no floppy disk activity the screen is now white have put up some picks and video (y)
Tomse
RISK is good
Denmark
Copenhagen
it looks like you have a minimegi chip.
try replacing that with the original Fat Agnus (if you have it)
remove the battery before more damage happens to the MB
otherwise it's difficult to see details with your current pics (out of focus).
what Rev is the board ?
AndyLandy
Acceleration!
Treasurer
Southampton
If it's an A1500-proper, it'll have an r6.3 or higher board.
tokyoracer
Yeah you really need to remove that battery ASAP. A pair of thin pliers should do the job.
dj.echo
EASTSUSSEX
new pic`s
new pic`s
better pic`s battery is now out rev 6 board
Merlin
Manchester
In that 4th picture (the one on the right) there seems to be some ass-nasty corrosion of the tracks just below the battery. Have you checked that those tracks still have continuity across the damaged (light green) sections?
Lugosi
Germany
Düsseldorf, NRW
It's not only the tracks by the battery...see the greenish color on the 68000, also inside the MMU/CPU slot, and even on the small chip behind it? :wooha:
That battery spread its "love" all over the place.
Imho some major scrubbing/neutralizing, socket-replacing and (possibly) track-repairing needs to be done.
dj.echo
EASTSUSSEX
yes
yes
yes that corrosion is about all the damage that you can see on the board as i said before thats the only damage i can see it goes right up to the chip can i patch it up with a conductive micro tip pen ? when i took the board out the back looks as good as new one thing i did see on the power supply and the board has amiga2000 on it and under the 1500 case badge it has 2000
Merlin
Manchester
OK, you need to do some things sharpish. get some spirit vinegar or lemon juice and clean the board with it whereever you see the green corrosion. vinegar or lemon juice neutralises the chemicals in the battery leakage that are causing the corrosion. Once you have done that, apply some iso propyl alcochol (car screenwash) to clean off the vinegar / lemon juice.
An old toothbrush (an electric one, if you are lazy like Zetr0 :LOL:) is ideal for this.
Leave it somewhere warm to dry for a day or two then let's have another look at the damaged areas. With luck, it may only be a track or two that has lost continuity.
