Hi all,
I'm having a really strange problem with both WinUAE and FS-UAE that I just cannot get my head around.
I'm trying to copy the complete collection of WHDLoad games to my CF Card destined for my A600 (and possibly going to do another for my A1200), but keep getting strange lockups during the file copy.
I'm copying the files from a folder PC side mounted as a psuedo-HD in WinUAE (or FS-UAE) and copying to my CF card which is already prepared using PFS (I've also tried FFS) and copying the files using Directory Opus 4.12 (iirc - it's whatever version is distributed with ClassicWB)
The problem I get is as follows: part wat through the copying process, it just pauses - the emulated Amiga is still functional, but the copying process just stops - there's no reading/writing going on anymore. It happens at random, there's no pattern. I end up having to reboot, but it regularly stops at the same filess - if I change something (like raising the amount of buffers in HDInstTools for the drive/partition I'm copying to) it'll get a bit further, but happens again. So basically, how the f*** am I suppose to actually copy this stuff???
I've tried the following:
- WinUAE 3.2.2.0 vs FS-UAE 2.6.2
- Changing Kickstart ROM version (tried 2.0, 3.0 and 3.1)
- Changing CPU (tried emulating the destination hardware exactly and tried emulating 68040 with quickest settings I can get away with)
- Tested under Windows 7 and Windows 10 host OS
- Tried writing to the CF card directly (mounting under WinUAE) and also tried making an image of the CF card (WinImage) and writing to that (under WinUAE and under FS-UAE)
- wiped the CF card / image, re-partitioned with PFS and tried again (and again tested with FFS instead)
- swaering and cursing
- I even reinstalled my laptop that I was doing this on, wiped the C: drive and reinstalled Win7 Pro
Any advise would be greatfully received!
I'm starting to lose my temper with all this WinUAE / FS-UAE stuff now. I'm running WHDLoad 18.2, not that this makes any difference, as the problem is just plain old AmigaDOS.
I've not tried copying with just a plain old AmigaDOS prompt yet, so wondering whether to try that next.
Any help greatfully received
woodycool
woodycool
