I wonder if someone here can give me some direction with Blizkick?
I have A1200 , 3.1 kiskstart ROMs with a Blizzard 1230 MKIV with 192Mb memory (SCSI board fitted but not being used at the moment) I had setup AmigaOS 3.9 with BB2 with ROM update and ClassicWB on WinUAE and this was transfered to a 40Gig IDE drive connected to a Elbox 4xEIDE'99 adapter. I use the seconfd IDE of the 4xEIDE'99 adapter for a CDRW / DVD drive. I have use the supplied Elbox driver for the 4xEIDE'99 adapter. In the startup-seqence I have the following right at the beginning:
C:4xEIDE.driver RESIDENT QUIET
also I removed:
IF EXISTS DEVS:scsi.device
C:LoadModule DEVS:scsi.device
EndIF
Everything works perfectly.
So my question is this: Where do I put the c:blizkick line - before or after C:4xEIDE.driver RESIDENT QUIET?
Once i know this i will start experimenting with blizkick.
Thanks for reading....
also I removed:
EndIF
