If you choose an A1200 you might have to wait a long time until there is no opportunity to get some spare parts. Commodore sold about 90.000 A1200 alone in Germany.
This is definitely only my opinion though. I don't know for certain that electronics are designed to fail. I would love to be told that I'm wrong too.
And keeping some broken Amigas around for parts instead of throwing them away will also be useful once you do get a problem as you'll likely have the parts to fix it.
I don't believe they're explicitly 'designed to fail', but they are made as cheaply as possible. Tolerances will be right on the border and things will so easily fail because the manufacturers could shave an extra few pennies off the cost by cutting corners in the designs. It's a fine line between this and 'designed to fail', though.
Plus most/all computers these days rely on optical media, which has always been flawed not only because the media itself is fragile but the drives are too.
That doesn't matter. What matters is the manufacturing precision and bearing tolerances, which is much higher in server-drives. They usually carry longer warranties as well for the same reason.Drives are not a problem anymore, I've got so many SCA80 drives now, that these should last for a while.
But I reckon these will fail quicker cause these run at 10000 rpm, or even 15000.
