ok its come to the point where i have over six thousand mp3s and its a nightmare finding the right ones.
What i want to do is a 2 part process.
Part 1:
This is not a problem plenty of free aps will do this..
Analyze the mp3 and detect they key its in "a major" "a flat" and so on. then add the key to the comments of the id3.
like i said that part is not an issue the problem is part 2.
part 2:
What i then want is an app that will read the comment data of the id3 and make a folder (a major) (a flat) and so on, then move (not copy) every mp3 with a coresponding id3 comment to the relivant folder..
i have looked and looked but all i can find is Use "xxx" program to id the key (not a problem)
then use itunes to make a smart playlist.. but that is not what i want to do..
I dont see how it could be difficult to simply make an app that moves the files to the correct folders..
I had "incorrectly" assumed that most if not all the key detection apps would do this as a feature. but it seems none of them do..
any help would be appretiated.
Even if i can do it from a bat file or something it would be preferable. beause 6k files is a Lot to manually check and individually move.
Part 1:
part 2:
