Swap IBM Butterfly 701CS keyboard only
  • Thread starter Thread starter istvan77
  • Views Views 272
istvan77
Rating - 0%
0   0   0
Hungary
Velence
I would like to swap a German layout IBM butterfly keyboard. PN 10H2603
I've tested in dos, with NortonCommander 5.0 and mostly works:
I had no response from: F9-F10, Druck, NumLock. Maybe Einfg-Entl.
Pause, F11-F12 untested.
The mouse is working, even we can see some corrosion on the small cable. It was working in NC5, the keys are also OK. Some random movement can be expected, like it came alive.
>< key likes to fall off, not broken, but it falls off sometimes. Now sits in place, I had to remove to make a photo...
Some very small damages around the edge, metal bezel (half bolt still remains)
I would like to swap for :
- One TFT (701C) LCD bezel. The bezel itself is enough, so I can fit maybe one more Butterfly. It is ok if it is broken, damaged, but can hold an LCD in place. If it comes with a not perfect LCD, it would be more joy!
- or a working dstn screen. No problem if it has issues, not perfect, but I can use on my test bench.
If no offer for swap, I'm willing to sell for other a Butterfly Rescue Squad.
I'm flexible on delivery, if you or your friend plans to visit Hungary, Budapest, I can meet there and hand over even after a year. (Hungary post costs are crazy)
If I don't respond here, feel free to poke me on FB.
