OKiez, I have two related (small) probs on two different machines. Im hoping someone can shed some light on a solution.
I have an A2000, 2mb chip, 3.1 rom, GVP 040 Combo with 16mb fast, will shortly have a Picasso II card installed. It is running OS 3.9 with BB 1,2,3.
I also have an A1200 running an Apollo 1260 with 32mb fast, 3.1 roms running a heavily modified install of AmigaSys 4 (based on wb 3.1).
Bot hsystems are currently storing icons in Chip Ram, which is just not on! I like nice 256 coloured (or even 24 bit once the Picasso card is installed) icons, so once I open a few Windows Im out of Chip Ram!
With OS 3.9, it is usually as simple as changing the Sys
refs/Workbench settings to store icons in OTHER MEMORY. Unfortunately this corrupts the gfx on the GVP Combo 040... and after opening/closing half a dozen windows the system, crashes. I know - weird.
With the A1200/3.1/AmigaSys 4 install, you dont have Sys
refs/Workbench at all, so there is no simple way of loading icons to fast ram. Now on this system I have replaced the 3.1 Setpatch, icon.library and workbench.library with the ones from OS 3.9, so I have Glowicon etc support. This is running fine.
I need to know how I can map the icons to fast in the A2000, OR will it be a different matter after installing the Picasso II? I already have Picasso96 installed, so perhaps this (without the gfx card) is causing the corruption/eventual crashing?
And on the A1200, how can I map the icons to fast ram? Is there a program/patch (could not find anything on Aminet)? Can Sys
refs/Workbench just be copied across to 3.1 now that I am using the 3.9 version of icon.library, setpatch and workbench.library?
