IDE angle connector for SD2IDE converter, dual port A600/A1200
  • Thread starter Thread starter Krashan
  • Replies Replies 223
  • Views Views 26653
Krashan
Vendor
Poland
Podlasie
This angle connector is designed for typical SD2IDE converters and SD cards in Amiga 600 and Amiga 1200. Additional 3.5" IDE port may be used to connect HDD or optical drive. No conflict with scandoublers, A600 turbo boards. Active correction of HDD LED signal. A jumper can be removed to disable the LED signal from the 3.5" port. Rigid and durable construction. Note that the connector may require the upper electromagnetic shield of Amiga to be removed.
As i have started a business of manufacturing these items, they are now only available via resellers. Check the list at rastport.com.
Batch VII: sold out
Note: SD2IDE converter and SD card shown on the second photo are not included.
Note2: Batch 7 is also listed elesewhere, so availability may change. However I can extend it if needed.
Batch VII
[TABLE="class: grid, width: 500, align: left"]
[TR][TD]scoopex[/TD][TD="align: center"]2[/TD][TD]received[/TD][/TR]
[TR][TD]supaduper[/TD][TD="align: center"]2[/TD][TD]received[/TD][/TR]
[TR][TD]Acill[/TD][TD="align: center"]1[/TD][TD]received[/TD][/TR]
[TR][TD]fabbie54[/TD][TD="align: center"]1[/TD][TD]received[/TD][/TR]
[TR][TD]walkero[/TD][TD="align: center"]1[/TD][TD]sent[/TD][/TR]
[TR][TD]mc68000[/TD][TD="align: center"]1[/TD][TD]sent[/TD][/TR]
[/TABLE]
Hi, I'm interested on two adapters.
Edited quantities.
Payment done.
Reserved 2 for a.mi.goun. Now all the 10 pieces are paid or reserved, so any new reservations can be only satisified if someone withdraws interest. However I plan another batch in a month or so. Also single port connectors (without 3.5" port) are also on the way.
Can you change my reservation for just 1? I would need only one if there are also single port ones. I would buy one dual port and two single port instead.
Received payment from soeter04.
Reserved one item for kgthomps.
Paid connectors will be sent tomorrow.
