Found Idefix Express for A1200
Bamiga2002
reasonable tradesman
Finland
Kinkomaa
Looking for this piece of HW.
http://www.jschoenfeld.com/products/idefix_e.htm
Idefix + express adapter, the whole thing!
Maybe i could also swap it for a Fast ATA MK III that i have.
Also if someone can enlighten me: what's the difference between a revision 1 & revision 2 Idefix Express?
Bamiga2002
Finland
Kinkomaa
So you'd have an extra clockport in use?
EDIT: can i still use the original clockport with this Idefix?
Tomse
RISK is good
Denmark
Copenhagen
Sorry, perhaps it's not my place to ask, but do it anyway.
Why do you want to swap the MKIII adapter (which runs with PIO mode 4) to an adapter that runs in PIO mode 2 ?
IMO what you have is better than what you want (as seen from the specs only).
If I had what you wanted, I'd swap with you :)
Bamiga2002
Finland
Kinkomaa
Good question and the reason for this is that i can't use my Lyra KB adapter with Fast ATA. There's no way. But with Idefix Express the Lyra fits nicely in place. And there seems to be no other keyboard adapter that supports multiple keypresses. I even happen to have 2 Lyra adapters unused ATM! :)
I don't care so much about the disk speed difference, because i still have BPPC scsi HD that i use the most (3.1 & 3.9 stuff). Fast ATA has been my OS4-partition drive only.
Bamiga2002
Finland
Kinkomaa
Seems like i'm in luck and getting an Idefix Express maybe even within this week! (y) outside of Amibay though.
So this thread can be closed i think :)
