Sold Individual Computers ACA1233n / 40 MHz with MMU + 68882 FPU + 128 MB
  • Thread starter Thread starter bobymiller
  • Replies Replies 5
  • Views Views 204
bobymiller
Germany
Rheinland-Pfalz
Hello,
I am downsizing my collection and selling a barely used ACA1233n turbo card with 40 MHz and 128 MB RAM from Individual Computers.
Features:​
  • Memory auto-configuration
  • Dynamic clocking for power-saving
  • card enable/disable in software
  • memory available to onboard CPU if accelerator is switched off
  • faster clockport for RapidRoad gives 55% speed increase
  • new software compatibility settings
  • improved A1200 compatibility
Memory of the ACA1233n is auto-configuring. This means that all memory is available from a power-up without installing any software on the computer. The old ACAtune tool, which was required for our previous accelerators, is not required any more.
If you do not require full speed, the card can be slowed down in order to save power. The CPU governor program will monitor CPU requirement and adapt to the demands of your application, resulting in the best power/performance ratio for your use case.
Some software does not like accelerated execution. For these cases, the ACA1233n can be switched off in two steps: The first step is to switch off the 68030 CPU and give control to the CPU of the host computer. On an A1200, you can still use 9MBytes of fast memory, which are also auto-configuring. The second step is to switch off additional memory as well, getting the computer into it's stock state. If used on an ACA500 or ACA500plus, memory can NOT be used by the 68ec000 processor.
The clockport of the ACA1233n can either take an RTC module, or the RapidRoad USB host controller. Operation of RapidRoad is 55% faster than with the internal clock port of the A1200 computer. This function is available in all modes of operation on an A1200 computer, and on the ACA500plus. It is not available if the ACA1233n is operated on an ACA500.
If software is not compatible with 32-bit memory, Z3 autoconfig or newer Kickstart version, the ACA1233n allows downgrading to Z2 autoconfig, older Kickstart versions and also lets you switch off the so-called "trapdoor memory area". The MapROM function is even available on an A1200 if the 68030 CPU is switched off! This will let you use different Kickstart ROM versions without opening the computer and exchanging ROM chips.
Price: 210,- €
Payment
: PayPal as F&F or bank transfer
Shipment prices (these are approximate):
EU - around 7-25EUR (tracked)
UK - around 20-25EUR (tracked)
US - around 25EUR (tracked)
