For Sale INDIVISION MKIIcr broken?
  • Thread starter Thread starter marco920
  • Replies Replies 11
  • Views Views 475
marco920
ITALIA
ROMA
I am selling INDIVISION MK2cr.
Not working due to my mistake.
I hadn't used it for 3 and a half years and, tired after working, I mounted it on my amiga 1200 but it didn't display anything. Then I realized something was wrong and that is, it was positioned incorrectly. I had mounted it on the wrong CIP....
I don't know if it can be repaired.....
if someone knows how to repair it I would be happy to repair it, otherwise I'm selling it as not working.
the video cable sometimes causes problems
I mounted it on the CIP VLSI
75€
Edit: it is impossible to ask a question on the icomp site to be able to send a question it asks you a very simple question to avoid spam (how much is 2 times 2 minus 2? TWO but it does not accept the answer.
Maybe try to contact icomp for support or help ?
Also it seems like there's some flux residue, did you attempt to reflow it, or was that there when you bought it?
it's not residue, I had glued (bostik) some pieces of foam rubber on which I had glued a cooling fan
gives the same anomaly when I want to register
This could be 2x2-2=2
but it could be also 2x(2-2)=0 ;)
I guess icomp uses an ultrasonic cleaner at their products because my ACA1233n has the most dry solder i have ever seen. Probably this is because of outdated solder.
Since the MKIIcr has been replaced by the MKIII for quite a while now, a qualified guess is that there is no spares and the repair cost for it would be higher than buying a new one. Also, since this is out of warranty IComp will charge you per hour as well.
So I would not have too high expectations to have it fixed :(
