installing a 68882 FPU to the A1200 motherboard
ColourWheel64
none
none
I've had a scout around the net for info and alas no joy, so I thought I'd throw it up here.
You know how an FPU 68881 or 68882) can be installed to a standard A1200 motherboard..
Well, I was wondering if it could work in tandem with the FPU installed in my Blizzard 030 MkIV.
BLTCON0
Math inside
Hellas (Greece)
Chania, Crete
If by "in tandem" you imply "both FPUs executing code", absolutely not.
Don't bother with it, even if you only ever plan to run the stock 68EC020 it's far easier to get a RAM card with an FPU installed.
zekstra
Serbia
Pozarevac
I was wondering the same question, too. With adequate soldering skill, is it really possible to put 881/882 fpu on A1200 motherboard?
demolition
Denmark
Copenhagen
If it is, it will not work with any accelerators anyway, only with the standard 020 CPU.
zekstra
Serbia
Pozarevac
Thanks demolition, it is exactly what I need to know. Stock A1200 with fpu added onboard.
roy_bates
resistance is futile!
england
birmingham
it would only work with 0-8mb ram cards that dont have a fpu on board,i said nope because there is already provision for a fpu on most if not all ram cards made for the 1200.
besides you would be limited to 14mhz on the fpu as far as i know
it can be fitted,although it would be pretty pointless/restricting...maybe even not very useful considering the limitations.
