Intel S5000PAL server board(s) with E5320 1.86GHz Xeon CPUs and RAM
  • Thread starter Thread starter 20Watt
  • Views Views 1508
20Watt
Scotland
Inverclyde
I have two Intel S5000PAL Socket 771 server boards with CPUs and RAM that I'm never going to do anything with. Both come with CPUs and RAM and were fully working when I tested them before putting them into dry storage last summer.
Board specs here: http://www.intel.com/support/motherboards/server/s5000pal/sb/CS-022639.htm
Motherboard #1 - £40 + shipping
S5000PAL motherboard - used but in original packaging
2x Intel E5320 1.86GHz SL9MV Xeon socket 771 CPUs (fitted to board) - no heatsinks
16GB of PC2-5300 (667MHz) ECC RAM - 8x 2GB DIMMS (fitted to board)
I/O shield
20140408_172032_zps7259f43b.jpg20140407_144127_zps78280e18.jpg20140408_172114_zps7edc5678.jpg
Motherboard #2 - £30 + shipping
S5000PAL motherboard - used without original packaging
1x Intel E5320 1.86GHz SL9MV Xeon socket 771 CPU (fitted to board) - no heatsink
8GB of PC2-5300 (667MHz) ECC RAM - 4x 2GB DIMMS (fitted to board)
I/O shield
[TD="class: bodycopy, bgcolor: #efefef"] Feature [/TD]
[TD="class: bodycopy, bgcolor: #efefef"] Description [/TD]
[TD="class: bodycopy, bgcolor: #ffffff"]Processors[/TD]
[TD="class: bodycopy, bgcolor: #ffffff"]771-pin LGA sockets supporting 1 or 2 Intel® Xeon® Processors 5000 Sequence, with system bus speeds of 667 MHz, 1066 MHz, or 1333 MHz[/TD]
[TD="class: bodycopy, bgcolor: #ffffff"]Memory[/TD]
[TD="class: bodycopy, bgcolor: #ffffff"]8 Keyed DIMM slots supporting fully buffered DIMM technology (FBDIMM) memory. 240-pin DDR2-533 and DDR2-677 FBDIMMs must be used.[/TD]
[TD="class: bodycopy, bgcolor: #ffffff"]Chipset[/TD]
[TD="class: bodycopy, bgcolor: #ffffff"]Intel® 5000 chipset family which includes the following components:
  • Intel® 5000P Memory Controller Hub (MCH)
  • Intel ESB2-E I/O Controller
[TD="bgcolor: #a6a6a6"]
[TD="class: bodycopy, bgcolor: #ffffff"] Note [/TD]
[TD="class: bodycopy, bgcolor: #ffffff"]Intel will make available an OEM SKU of this server board using the Intel® 5000X Memory Controller Hub (MCH).[/TD]
[/TD]
[/TD]
[TD="class: bodycopy, bgcolor: #ffffff"]On-board Connectors/Headers[/TD]
[TD="class: bodycopy, bgcolor: #ffffff"]External connections:
  • Stacked PS/2* ports for keyboard and mouse
  • RJ45 Serial B port
  • Two RJ45 NIC connectors for 10/100/1000 Mb connections
  • Two USB 2.0 ports
  • Video Connector
Internal connectors/headers:
  • One USB port header, capable of providing two USB 2.0 ports
  • One DH10 Serial A header
  • Six SATA ports via ESB2 supporting 3Gb/s and integrated SW RAID 0/1 support
  • One 44pin (power + I/O) ATA/100 connector for optical drive support
  • One Intel® Remote Management Module (RMM) connector (RMM use is optional)
One I/O Module Connector supporting:
  • Dual GB NIC I/O Module (Optional)
  • External SAS Module (Optional)
  • SSI-compliant 24-pin control panel header
  • SSI-compliant 24-pin main power connector, supporting the ATX-12V standard on the first 20 pins
  • 8-Pin +12V Processor Power Connector
[/TD]
[TD="class: bodycopy, bgcolor: #ffffff"]Add-in PCI, PCI-X*, PCI Express* Cards[/TD]
  • One low profile riser slot supporting 1U or 2U PCIe* riser cards
  • One Full-height riser slot supporting 1U or 2U PCI-X* and PCIe riser cards
[/TD]
[TD="class: bodycopy, bgcolor: #ffffff"]On-board Video[/TD]
[TD="class: bodycopy, bgcolor: #ffffff"]ATI* ES1000 video controller with 16MB DDR SDRAM[/TD]
[TD="class: bodycopy, bgcolor: #ffffff"]On-board Hard Drive Controller[/TD]
  • Six ESB2 3Gb/s SATA ports.
  • Intel® Embedded Server RAID Technology II with SW RAID levels 0/1/10.
  • Optional support for driver-based RAID 5 (requires Intel® RAID Activation Key AXXRAKSW5).
    1See note below.
[/TD]
[TD="class: bodycopy, bgcolor: #ffffff"]LAN[/TD]
[TD="class: bodycopy, bgcolor: #ffffff"]Two 10/100/1000 Intel® 82563EB Gigabit Ethernet PHYs supporting Intel® I/O Acceleration Technology (Intel® I/OAT)[/TD]
[TD="class: bodycopy, bgcolor: #ffffff"]System Fans[/TD]
[TD="class: bodycopy, bgcolor: #ffffff"]Six 4-pin Fan Headers supporting two processor fans, and four system fans[/TD]
[TD="class: bodycopy, bgcolor: #ffffff"]System Management[/TD]
[TD="class: bodycopy, bgcolor: #ffffff"]Support for Intel® System Management Software and the Intel® Remote Management Module [/TD]
