SOLD > PAYMENT RECEIVED > Silverman71 > Tracking Details Given.
Asking £69+Postage
POSTAGE:
UK Mainland £6.97
EU £8.95
Rest of the World £10.95
This item is used, but in 'as new condition' unboxed. I paid over £110 new.
I've used this in both my Amiga 2000 and Amiga 4000. You can 'hot swap' SD Cards. It works 'really' well.
The last two pictures are from the manufacturer's website, so you can see the SD Card PCB clearly. I still have the protective film on mine.
You can remove the PCB from the little case (it has 4 mounting holes) and mount it however you wish internally or externally.
(No SD Card Included)
Drivers attached to this post.
SD Drive is a Zorro 2 card, compatible with all Amiga models equipped with Zorro 2 or 3 bus, including the most popular A2000/A3000/A4000 machines, running AmigaOS 1.2 - 3.9.
On the software side only 3 files are required: the device driver (DEVS: directory), the mountlist entry (SD0:, copy it into DEVS
OSDrivers) and the filesystem. The FAT95 filesystem should be available in L: directory. That's all.
SD Drive supports dynamic card sizing and hot swapping. No need to reboot the Amiga to mount a new SD card. It works exactly like a regular floppy or ZIP disk, but with much more capacity and incredible transfer rate!
Asking £69+Postage
POSTAGE:
UK Mainland £6.97
EU £8.95
