Joysticks on bbc micro/master
Station240
Adelaide,Australia
South Australia
The normal joysticks for BBC micros (including the Master 128, but not the Master Compact) are analogue. Connected to the 15 pin Dsub on the back, 4 analogue inputs, 2 digital inputs.
For a digital joystick, you most likely need to use the 20 pin IDC connector on the bottom called the userport, and then need software that supports it. I other words, a custom solution.
sir_beaker
Alresford
All analogue my friend. Roy was looking at making a digital adapter (y) I think Kempston made a digital joystick if you can hunt one down?
