KCS power board - red white strips
mjnurney
we live as we dream. Alone.
england
Milton Keynes
is anyone an expert on the KCS board?
the one I've just bought seems to have an issue...red/white stripes.
The software reports Boards ok as it loads up but then it fails to this ? I've tried different versions of the software. the only fault i can find is that the battery is dead, so I've removed it. no change nice stripes..
My A500
Rev5 Pal 512K ram.
1.3 or 2 kickstart
it doesn't like.
ACA500 , either runs ok or complete freeze. green screen or ACA500 error about corrupt flash.
A500+ , power cycles - no boot.
mike.
hang on...
5.2 Changing batteries
The following is not applicable to the AMIGA 500 +, as the KCS POWER PC BOARD
does not contain a battery for that computer type. Theoretically the life of the batteries
that feed the hardware clock is 8 to 12 years. After this period, or sooner if the battery is
empty, it has to be replaced. The battery ensures that a number of important settings for
the KCS POWER PC BOARD are stored, even after switching off your AMIGA. Without
the battery, or with an empty battery, the KCS POWER PC BOARD will not function.
But also if the battery is shortcircuited or removed briefly, the KCS POWER PC BOARD
will no longer function, as the fore-mentioned settings will be lost. After installing a new
battery the KCS POWER PC BOARD will still not function. First the settings must be
transferred again to the KCS POWER PC BOARD.
If you suspect the battery is empty, follow the procedure for installing the clock, as
written in § 3.2, where a number of settings are saved to the KCS POWER PC BOARD.
If after that, the clock on the KCS POWER PC BOARD still is not working, then it is
possible that the battery is empty and needs replacing. In this case, contact your dealer or
KCS.
C 1992 KCS BV, THE NETHERLANDS V4.5 - 28
nope still no go :-(
roy_bates
resistance is futile!
england
birmingham
dont really know alot about these cards.
is there a chance the memory is bad?
mjnurney
england
Milton Keynes
i wasn't sure roy , the cpu never got warm so i was thinking thats dead but guess what...it was the install disk. I've made a new floppy with the last version ADF and it booted instantly
so happy days ...now just to get vista on it :)
roy_bates
england
birmingham
never would of thought it was the floppy,lol
vista...whats that?,lol
mjnurney
england
Milton Keynes
vista may be a resource hog...maybe XP
dougal
Malta
Glad you got it working :)
I really ought to set mine up too. I had tested it but never really messed around with it proper.
deladrevoc
Hampshire
Cool cards these, I wish I'd had mine back in the day. It took me 30 minutes to compile 1000 lines of Turbo Pascal code using a software PC emulator. I'd spent 3 solid days and nights coding to submit my A level project on time :(
You may get Windows 3.1 to run on it :)
BlindGerMan
Dancing with bridgeboards
Germany
Bavaria
Windows 3.11 ftw lol!
I always look at these cards and wonder, should I get one just for the fun of it :D
Well, Windows 3.11 is not possible because it would not run on a 8086/88 CPU! But 3.0 is working fine! I have a KCS PowerPC Board for my A600 with 030 Turbocard with EGA Emulation it is really not bad! ;)
mjnurney
england
Milton Keynes
i have a couple of videos up in the photo section of it running a couple of games.
you should put some pics on of the A600 version.
BlindGerMan
Germany
Bavaria
Here starting Windows 3.0...
mjnurney
england
Milton Keynes
awesome , i haven't tried windows yet.
The stripe error that i had doesn't happen with a ram expansion attached. (4mb on zorro slot) Video speed increases slightly too
odd but true.
a little video
http://youtu.be/xFyMwGMOQ_w
