Wanted Looking for a Capacitor for a2386 Bridgeboard
ShadowRider85
Rating - 0%
0   0   0
UAE
Abu Dhabi
Hello All. I am in the process of repairing a 386 Bridgeboard , and i am trying to find a Capacitior... B9HC0118 101 KX8 (location on the board is CP501,502, 503, 503). any help is greatly appreciated!
David
For the Cap size for CP501, 502, 503., 504 are all 100pf not sure where you can find them..
my have found some.... attached photo, if anyone else is looking
Hope it is not a scam! will keep results posted
This was posted a few years back concerning the same issue....
By
useroff.gif Castellen
  • Hero Member
on Amiga.org forum
"I see the ones you're looking at. They're capacitor networks, I.E. 8 capacitors in 1 package. They're a
bit specialized and sometimes hard to find though.
The writing says 101kx8 which means there are 8 100pF capacitors.
Looking at the circuit, each capacitor simply sits across each floppy
signal pin and ground, so they're used for RF decoupling.
That means the board should still work fine without them, but I
suggest keeping ribbon cables as short as possible to minimize
noise/RF pickup.
If you wanted to fix it properly, and can't find a capacitor network,
then here's what I'd do:
Find someone who sells chip components and buy some 0805 sized 100p
caps. On the solder side (bottom) of the board on the actual header
pins, solder each cap vertically between the signal pins (top
row) and the ground pins (bottom row). One cap per pair of pins.
On the floppy connector every even numbered pin is ground.
Hope that helps,
Anthony."
