Closed Low-power 2x32MB EDO RAM for Apollo 1260
  • Thread starter Thread starter Photon
  • Replies Replies 2
  • Views Views 980
Photon
Amiga is Yes. :)
Sweden
Smaland
I have two 32MB sticks, they are 3.3V 'GoldenRAM' 72-pin EDO 60ns RAMs, with 16 chips each, GM71C17403CJ6. These:
Now, I'm trying to make a PSU with 6A on the 3.3V like both the 68060 @ 100MHz and two 32MB sticks.
Unfortunately, this means that the RAM sticks must consume less than half the power of these ones, or max 1.7A (5.6W) for both.
That was for the super pros, long story short I'd like to buy 2 tested working 50-70ns 32MB memory sticks from you if they
1) Are made later than 1999
2) or have fewer than 16 chips on each stick
3) or are known to have a smaller manufacturing process than mine ('microns')
If you don't know these specs you can post the chip numbers and I can google some info.
Pfwoah, to be honest I don't know how the Apollo is wired. But you're absolutely correct. Doh. :) It's right there in the picture too, didn't check it and it was a long time since I shopped for these RAMs so I forgot. Unless the RAM can run at 3.3V and actually does (which is very unlikely), I would gain nothing by swapping for new RAMs.
Thanks stachu :)
Admins may close this thread.
