Microsoft Xbox 360 Elite (250Gb)
  • Thread starter Thread starter PureChaosX
  • Views Views 748
PureChaosX
Northampton
The Xbox 360 is in full working order, reads DVDs and CDs without a problem and connects to Xbox Live via the Ethernet port using a wireless network extender.
What's Been Done:
The whole shell has been replaced (top, bottom, faceplate)
The chrome DVD bezel has been replaced
The hard drive caddy has been replaced
The hard drive has been upgraded from 120Gb to 250Gb
The DVD drive has been lubricated as the tray would often stick
The power supply has been replaced
New thermal paste has been applied to the CPU and GPU
What's Included:
Xbox 360 Elite 250Gb
1x Controller... the "new" black one, not the one with the grey D-Pad and thumbsticks
1x Gold Plated HDMI Cable
1x Ethernet Cable
1x Power Brick
1x Power Cable
Will throw in Burnout: Revenge
The only noticeable cosmetic issues are two small scratches on the controller and a few scuffs on the HDD caddy. Other than that, the replacement shell is in very good condition.
You may notice the serial number sticker has been removed. This is because the S/N no longer matched with the original motherboard (since the top panel was replaced) and therefore the S/N wouldn't have worked. I have however taken a photo of the original S/N and will provide a printout so if it's needed, you'll be able to use it.
The DVD drive used to stick when trying to open it, but with some lubricant and a belt replacement, it seems to be working fine. Have played some Ridge Racer 6 on it for an hour without a problem, no overheating issues, no disc reading issues. Haven't been able to test the Wi-Fi adapter as I do not have one, but I have tested it via the Ethernet port using a wireless extender.. so it's kinda wireless.
CLICK HERE to see the album of photos for the console.
Selling for £60 and £5 postage. PayPal only, select as Gift so as to not incur any additional fees, postage to UK only.
