Closed Mimimig 60Hz NTSC core
ghoul
Rating - 96.8%
30   1   0
Poland / UK
Does anyone still have the 60Hz NTSC core for Minimig that works with LCD monitors not supporting 50Hz hacked by Yaqube?
I've tried uncle google but was unable to source this one from anywhere :( Any help would be appreciated :)
chaos
Slovenia
Ljubljana
I believe all minimig cores support NTSC & 60Hz, it's just that by default the minimig is in PAL mode. You can save a config with NTSC enabled, or alternatively, hold F1 on the keyboard or the RESET button on minimig while booting and that should switch minimig into NTSC as well.
Also a new core could be built that has NTSC enabled by default.
ghoul
Rating - 96.8%
30   1   0
Poland / UK
Many thanks chaos! I've already found this info apart from holding the reset button while booting, thank you will try this tonight! :)
