I have the following for sale. Prices include UK Postage Only
** Trades Interested In **
Megadrive Games CIB
Master System Games CIB
8Bitdo / Retrobit Megadrive Wireless Pads
Mega Everdrive Pro
This Mister FPGA bundle comprises of the following...
Looking for £325 delivered
A Jammix ITX board - https://www.jammix.io/
This board allows you to run the Mister in any arcade Jamma cab thanks to its Jamma connector. Additionally, it allows you to install teh Mister into an ITX case and provides plenty of additional benefits if doing so including...
This board was received a few days ago and fully tested. It cost me £280 + £58 in custom charges from the maker of the board in Portugal.
I'm letting this go for a bargain price of just £150 Delivered (and will include the ITX case in the pictures free!)
** Or take both the Mister setup and Jammix ITX board for £425 delivered **
Advertised Elsewhere
B/T or PPGift (Friends & Family) Only Please. Plenty of feedback on RLLMUK and AVForums for those who don't know me.
Megadrive Games CIB
Mega Everdrive Pro
- DE-10 Nano with copper heat sink
- 128MB memory module
- Digital I/O board with fan
- USB board
- WiFi dongle
- Bluetooth Dongle
- Meanwell Upgraded 5V / 6A PSU and cable
- 128GB micro SD card with Update-All script run.
- Clear acrylic case
- Hundreds of ITX / DTX / ATX case options available on the market
- Simultaneous buffered RGB output via JAMMA and “VGA” port
- Sync-On-Y circuit, for Component output via "VGA" port (JAMMA RGB output not available in Component mode)
- JAMMA RGB levels are 4V (p-p), for best compatibility with standard arcade monitors with buffered TTL Csync output on JAMMA edge
- Onboard Stereo audio amp, for Neo Geo style cabinets. Neo Geo MVS harness compatible
- I2S audio DAC for higher quality analog output
- Buffered Audio line-out
- Audio line-in (no need for the standard ADC addon)
- Onboard USB 2.0 hub. Four External USB 2.0 ports, two on an internal header
- Ethernet routed to the IO shield
- Self-resetting (PTC) fuses on all USB ports, DE10 Nano, and User port (SNAC)
- Overvoltage protection on the 5V rail, to help protect the DE10, USB devices, and JAMMIX (OVP works whether using JAMMA, ATX, or 5V DC jack)
- Multiple power options ATX, JAMMA or 5V DC jack
- ATX power with soft power on/off, and front panel buttons/LEDs headers (soft power option also available when powered via JAMMA or 5V DC jack)
- JAMMA edge connector, with “Gold fingers” and beveled edge, to prevent damage to the harness socket
- Support for the extra “CHAMMA” style button inputs, for up to six buttons per Player 1 & 2
- CPS2 style "Kick" header, with 22 extra player control inputs, including configurable support for Players 3 & 4
- Replicates the functions of the v6.1 IO Board (LED outputs and button inputs are available on the front panel header. Secondary SD signals broken out to a header.)
- Mounting holes for 2.5" HDD/SSD
- Expansion board addons for enhanced IO available in the future.
