Mitsumi rubber dome keycaps A2000,A3000,A4000
  • Thread starter Thread starter gifair
  • Views Views 958
gifair
Denmark
Djursland
tl;dr: Looking for: left alt, f1, f6, esc - ruber dome type key-caps
I have managed to get a keyboard for my a4000 (yay).. Unfortunetly the keyboard had a few broken keys, apart from this the keyboard is in very good condition (very little yellowing).
I don't know the full history of this keyboard but my guess is that someone tried to remove the keys (maybe to clean the keyboard) without a keypuller and managed to break some of the keys.
Hence I'm looking for a few replacement keycaps - however upon closer investegation I have found that they keyboard is not the normal mitsumi spring-loaded keyboard, instead it's the "earlier" rubber dome/cup mitsumi type.
Above is a key shown next to a (very yellowed) key that I pulled from an A500 keyboard
What is special about these key-caps is that the center-hole in the stub on the underside of the keyboard is larger, hence the wall-thickness is less than the spring supported key type. This is probably a contributing reason as to why the keycaps broke in the first place.
(it is the type on the left I am looking for)
The more robust type (the one I pulled from the A500 keyboard) are able to fit and work with they keyboard - however since the stub is also slightly higher the result is that they are slightly higher than the other keys (not a great solution).
The keys I am looking for are:
  • Left Alt
  • F1
  • F6
  • ESC
And 1 spare rubber dome
Additional information - just for fun
It appears that they keyboard is originally intended for the A3000
However the inside membrane indicates that it's originally build for the A2000
The keyboard has a german layout - I suspect that Commodore Germany had a bunch of spare A2000 keyboards which they transplanted into A3000 keyboard cases to fill a supply shortage of German layout A3000 keyboards at some point (but this is just speculation).
Also if someone have a danish keyboard of this type and would rather have germay layout then I am interested in trading keycaps to make this happen.
