I currently have 3 mouses at my disposal, two from Amiga 1000s and one from a 2000 or 3000. One of the ones from the 1000s will not move the cursor horizontally, just stays on left side of screen and will move up and down. Using the mouse from a 2000 or later, it works fine on both 1000s. One of the 1000 mouses (mice) works right (or left) sometimes, but not always. Does not matter if it is on WB (1.3 or 2.0, depending on the 1000). One needs KS 1.3 and the other has a 2.0 ROM. Same problem if a program is loaded from the floppy disk. I have taken both mouses apart and sprayed with electronic cleaner. I don't know if this is a hardware of software problem. Any suggestions would be appreciated. Thanks.
