This as turned into a bit of a head scratcher for me.
I was lucky enough to have been given an Mp3@64 for Christmas and I have been looking forward for an opportunity to install this and to that end, decided to put a bit of time aside today.
Unfortunately, the device itself doesn't clearly mark where pin 1 is, one corner does appear to have a silvered circular mark that 'could' indicate pin 1, or it could just be a blob of solder. :huh:
I know that the clockport on the 1200 chucks 5v down one line so I'm quite keen to avoid any "Magic Smoke" incidents, and the warnings I have read about correct orientation have ranged from dire to catastrophic.
Therefore I have spent much of today and this evening fruitlessly searching for an inkling to the correct installation orientation.
I am also planning on using a cable to connect the expansion so that I can hopefully fit it adjacent to the existing audio outputs. Is there likely to be much degradation in signal caused by a cable that is 20cm long?
Any help would be most gratefully received.
