Closed MSI E7210 MasterX-FS Xeon DP Motherboard + 2 x 2.66GHz CPU
domb
Portsmouth
Hi Guys
Dropped the price to £35 including UK shipping, anyone interested?
I'm having a further clear out of PC stuff. I have the following available for £35 including insured postage to a UK address. I will contribute £7 towards the cost of postage to other destinations if anyone is interested.
The board is nearly new and fully boxed (used for around a week). It was purchased for a project which was never undertaken. Features include an Intel E7210 Chipset, Dual Socket 604, PCI-X. 2 x Onboard Intel Gig-e, Onboard Adaptec Ultra320 (including HostRAID firmware), a couple ICH SATA Ports, AC97 audio and a ATI Rage XL.
Also included are two Intel DP 2.66GHz Xeon processors and brand new heatsinks. 768MB of DDR memory is included on the motherboard to get you started.
The board is fully tested including a memtest86+. This motherboard will require an EPS12V PSU (24+8). I can however provide pin outs to make it work on a PSU which includes a 24 Pin header, 4 Pin 12V and an additional PCI-E 12v line. The 8 Pin header on EPS12V provides 4 additional 12V lines. These can often be sourced from the PCI-E lines of a good PSU.
Key Specifications E7210 MasterX-FS:
Manufacturer MSI
Manufacturer Part # MS-9156-010
CPU Support Socket Type Socket 604
CPUs Supported
Single/Dual Xeon
Front Side Bus Speed (FSB) 400MHz, 533MHz
Form Factor ATX
Chipsets Intel E7210 Chipset
BIOS Type 4 Mbit Flash EEPROM
PCI 2.2 compliant, VPD, and DMI
PnP 1.0A, SMBIOS 2.3, ACPI 2.0
Supports PXE boot protocol
APM 1.2, WOL, WOR
PC2001 system design compliant
Motherboard Color Green
Memory Number of Slots 4 x DDR266/333 DIMM Memory
Memory Type
DDR SDRAM
Maximum Memory 4GB
Storage Storage Controllers 1 x IDE connectors onboard/can connect up to 2 Ultra ATA drives
2 x SATA connectors onboard/can connect up to 2 Serial ATA drives
1 x Adaptec AIC-7901 Ultra-320 SCSI controller
Integrated Features Video ATI Rage™ XL graphics controller
Network Intel® 82547EI Gigabit Ethernet Controller
Intel® 82541GI Gigabit Ethernet Controller
Audio AC’97 link controller integrated in Hance Rapids ICH
Expansion Slots PCI 2 x PCI-X (64-bit/100MHz)
2 x PCI (32-bit/33MHz)
Ports • 1 floppy port supports 2 FDDs with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes
• 2 serial ports (COM1 & COM2)
• 1 VGA port
• 4 USB 2.0 ports (Rear * 2/ Front * 2)
• 2 RJ45 LAN jacks
Other Features Power Management:
• Wake up on LAN (WOL), USB, PCI, Mouse
• RTC alarm
• Supports ACPI S1, S4, and S5 functions
Server Management:
• SMBus (I2C)
• Hardware monitoring
• Thermal protection
• Chassis intrusion
Dimensions
(W x D) Unit 12" x 10" (ATX)
imnogeek
Midlands
Re: MSI E7210 MasterX-FS Xeon DP Motherboard + 2 x 2.66GHz CPU
That is sweet, I wouldn't have built my quad a few weeks ago if this had been available then.
Good luck with your sale, whoever gets this will have endless fun with those Xeons on board :)
Gary
domb
Portsmouth
Price Reduction
Price Reduction
Hi Guys
Bump folliwng price reduction to £35 inc UK shipping!
Cheers
