Mtec 1230
JLPedro
Portugal
Coimbra
Got this card in in a bundle of hardware, card sold as faulty.
Decided to test it and the card gives a green screen when powerd up on my A1200 1D4 mobo, kick 3.0.
At first thougt of bad ram simm but tested with known good simm and the result is the same, boots with green screen.
No visible damage on the board. Tested also with and without the RTC jumper.
Any ideas?
Seaside
Athens
Any ideas?
Once i had a Magnum 1230 with kick 3.1 while the card was ok in the workbench suddenly the a1200 hanged. With kick 3.0 this magnum worked fine in another machine.
Did you changed the memory in the Mtec ? Looked for any kind of corrosion ? Checked the jumpers ?
Did you test your Mtec with 3.1 kick ?
dabone
United Stated
Chattanooga, TN 37421
Clean the card contacts, I used circuit cleaner, a fine non fuzzy cloth (I think mine was a old pillow case), and a credit card cut to fit the openings on the connector.
I had all sorts of problems with a accelerator I used to have until I cleaned those.
Later,
dabone
Xanxi
France
Paris
What about booting without RAM?
Marc
Essex
Any ideas?
Look around the battery area. Is it making good clearance from the board?
JLPedro
Portugal
Coimbra
So I'll first clean the card with isopropilic alcohol and the try without ram setting the jumpers to 0 ram.
JLPedro
Portugal
Coimbra
Ok, board cleaned (more cleaning and i'll erase the board ... lol), tested with kick 3.1 and 3.0, green screen with both, tested with "turbo" jumper boots fine but board is not detected (no 030 cpu or ram).
Disabled ram to 0 and rtc off, green screen, cache disabled, green screen.
Again with diferent simms and no good. Defenetly some damaged chip.
Hope's off on a bargain... :(
edit: also tested with board set to 2mb , 4mb and 8mb
Marc
Essex
Have you tried removing the battery?
JLPedro
Portugal
Coimbra
I think disabling the RTC is the same thing (battery is clear from the board and looks fine).
Is this card worth the trouble of sending it to someone to repair?
