For sale a Multifix-AGA, a flicker-fixer and scandoubler for Amiga 2000 3000 4000. Project is open-source by Matze (Matthias Heinrich). PCB is the last hardware revision (v0.3a). More informations here:
gitlab.com
Item is new, components are all NEW or NOS from Mouser and Utsource.
Features of MultiFix-AGA:
- board doesn't provide USB functionality and the USB port is only to power external devices, unless you connect a USB host (such as Deneb or RapidRoad) to the internal pinheader;
- board was not tested in NTSC machines that may need a different timing;
- board is not compatible with A2000 v4.x boards;
- board is not compatible with OCS Denise;
- in A2000 models, jumper J300 (near odd CIA) must be set to position 1-2 (TICK must be generated by PSU, not by Agnus).
Request is EUR 135, payment by PayPal (friend and family or add fees).
Shipping cost is EUR 12 (UPS courier) for most european countries, in doubt just ask!
View attachment VID-20250221-WA0004.mp4
Matthias Heinrichs / Multifix-AGA · GitLab
This is a FlikerFixer for OCS/ECS and AGA-Machines
- supports AGA and ECS machines Amiga 2000/3000/4000;
- the resulting picture is sharp and crystal clear;
- supported resolutions: LoRes, LoRes Interlaced, HiRes, HiRes Interlaced;
- tested on PAL machines. NTSC mode in PAL machines works also well;
- internal pinheader is compatible with the RTG Card 'GBAPII++';
- no need for an adjustable capacitor as in the Commodore A2320 de-interlacer board, this was solved with an ICS570 clock multiplier;
- sync on green capability;
- positive and negative blank select;
- external USB connector, but only to power external devices such as HDMI converters. There is no USB functionality!
- headphone connector to directly bypass the audio signals from the Amiga video slot.
