Ok, so I had decided to open my Amiga 500 (which I own since 1992) and remove the battery from the trapdoor A501 expansion, which I did.
While I was at it I had to remove the insulation layer and I also cleaned the motherboard (which hadn't seen the light of day since 1992). Turns out it is a Rev 8 motherboard manufactured in November 1991 - with the Fat Agnus 8375 390544-01. It is Kickstart 1.3
The Chinon drive isn't working properly so I'll eventually buy a Gotek to replace it. Is it too hard to put in internally or should I opt for a DF1 external version?
Any other upgrades you'd recommend? Realistically I just want to do some retrogaming and watch some demos. I'd like to have 1meg Chip Memory - but it seems a hard for my soldering skills (solder additional RAM chips and fiddle with jumper blobs of solder...
Is it worth to upgrade the ROM to something more modern? Which ROM version?
Cheers and thanks for any advice/feedback!
