So after reading and seeing how rare the Amiga 500 + is in NTSC form, I was always curious and on the lookout for one. I even took the plunge and got a PAL one from Airey36 on eBay this summer as I wanted to mess with one.
Well I just found one on eBay that was NTSC so I grabbed it. The seller had two, one with severe but cleaned up Battery leakage, and the other, with none. Both were tested working and showing a screen shot of ShowConfig on the auction. I decided to get the non leaked one for a reasonable "USA" price.
Board arrived and it looked great. There seems to be no battery leakage on it, battery was snipped before it was too late.
But I was NOT happy so see that it had 3 broken pins on the second joystick port! I guess I can solder in a new DB9 connector, shouldn't be too hard... part ordered.
Fired it up, and the Kickstart 3.1 insert WB screen came right up!
Next, tried to boot my WB 3.1 disk. It seemed to struggle booting it and crashes right before WB would show up (black screen) and reboots. I got a GURU 8100 00FF.
Turned off pressed down on all socketted chips and tried again. Same thing. Tried a few more power cycles, was getting some GURUs on power on (like it sometimes does on other Amigas when powering on too soon?)
Booted some other disks, seemed to work ok.
Tried WB disk again, ok finally booted.
Then randomly it would crash to back screen and reboot to GURU.
Well over the course of the night and next day, it seems like its getting better and more stable but still crashes.
I hooked up a slingshot with A2091 and it seems to be working ok, left it on overnight with DoPus 4 running and when I woke up it had rebooted.
What can I try next?
---------- Post added at 10:14 ---------- Previous post was at 09:59 ----------
Next I ordered an A500+ top and bottom case from airey36 on eBay. Since these are truely rare as hens teeth in North America!
Now to find a keyboard and floppy drive for it.
