Closed Nano SwinSID
  • Replies Replies 54
  • Views Views 16926
gazcbm
10 PRINT "8 Bit Hero"
Manchester, UK
I have a bunch of Nano SwinSIDS for sale. These are around the same form factor as the original SID and therefore a great drop-in replacement for faulty or missing SID chips
UK £11 inc delivery
UK £12 inc recorded delivery
US £13.50 inc delivery
US £18.80 recorded delivery
Europe £13 inc delivery
Europe £18.30 recorded delivery
You pay paypal fees
About
SwinSID is a hardware replacement for legendary SID sound chip which was placed in every Commodore C64 computer. This hardware extension is designed as a module installed directly into the SID socket. It emulates the sound of the SID chip, but it is a lot more powerful and allows you experience the new dimension of C64 music. SwinSID can be used as a replacement for both old and new revisions of SID. It just emulates almost full register set of standard SID, and almost all applications and hardware devices, which uses SID, should work properly.
These are some samples I have recorded myself direct from a Nano SwinSID on a C64c
Ocean Loader 4
Thing Bounces Back
Ocean Loader 2
I'll take one buddy. I'm on a bit of an 8bit upgrade fix at the moment. :)
im interested in one unit.
is there a link please,to some info?
are there different types for different sids and motherboards etc? or are they just plug and play?
Link for info
http://www.swinkels.tvtom.pl/swinsid/swinsid2.htm
There is just one chip and it's capable of working on all motherboards and has a jumper that can be used to change between 6581 & 8580 emulation.
There is space on the chip to solder a 1k volume resistor for older c64's but from my testing its barely noticeable.
Link for info
when you say for use on all motherboards some sids use 12 volts some use 9 volts,but theres no mention as far as i could see in that link.
could you kindly confirm it will work with different voltages please.
also,do you know if i would have to remove the filter caps from the motherboard or not,thanks.as they are also different.
yes,i should of asked for a tech sheet or something.
but i think its better to ask than not at all.
if it does, please send me the paypal details via pm for recorded post thanks.:)
As far as I can tell, it is not using the 9V/12V pin, and it runs only from the 5V supply, thus it will work in any C64 board.
The filters are digital which means the filter capacitors are also not used, so their capacitance does not matter.
Swinsids shipped for chinners, roy_bates and r0jaws
Arrived over the weekend. All looks good. Now, I've to open my c64c... bye bye warranty :)
+ve feedback left :thumbsup:
Arrived Saturday, going to mess about with it later on tonight. Cheers buddy. :)
