I have a SX32, when I got it I removed the battery and try to clean as good as possible the acid, but now it's playing up.
The acid is under the IDE controller. Ther is pin 1 is broken off. I want that replace it to a new IDE port.
Sometimes the hard disk doesn't show up or give me a read error, after I reboot. It works fine. There is also a problem with the memory. I aso swapped for serveral SIMMs, but It doesn't work.
Can someone look at it and repair my SX32 Expansion?
