Need help with Amiga2000
Rambo60
nsw
i have two Amiga200 with the same fault problem i found the kickstart on most of the pin test with a logic probe there no pulse to the A(1:23) and the D(0:15) which go to the cpu and the cpu mc68000 has the same problem as the kickstart and only half of the ram is working i have test all parts and change all parts and still have the same problem and the power supply is ok
I have check all tracks and pads there are no bad tracks and corrosion
The Amiga diagnostic color on the screen it don't all ways help it was green well I replace the Ram still the same problem
if you need more ifo please let me no
