I've got a 100Mbps connection at home.
Doing a speed test I was only getting 30-40mbps so I go to my router/modem settings and change the channel and it goes to 80-95mbps which is awesome on wifi. Problem is that after some time, anything from 30 minutes to 2 hours it reverts to 30-40 mbps again and I have to do the same thing.
I've tried setting of dual band 20mhz/40mhz and just 20mhz and auto channel selection or just setting channel manually. Same story, speeds up to 80-90 for a while and then slows again afaterwards to 30-40 until I change channel again.
Anyone know how I can solve this ? When I called my ISP they said 40 is normal on wireless even if right next to the modem because of interference from devices, other routers (of neighbors) etc..
The router/modem is a cable modem by Cisco
