Noob Question about Kickstart/Modules, etc
  • Replies Replies 6
  • Views Views 1941
fitzsteve
Retired Slacker
Assistant
Sevenoaks
Hi Chaps and Chappesses :)
I now have Deneb's in my A4000's amd messed with the onboard flash for the first time...
I'm just wondering if the modules on the below link:
http://lilliput.amiga-projects.net/ROM_modules.htm
If they can be dropped straight into the Deneb's Flash and used 'as is' or is there something else I need to do?
I used Lucifern to remove the bits I didn't need like the animation/requester so am now familiar with the flashing process.
Cheers!
Steve.
Yep Steve my friend you can simple drop them via Luciferin :)
They are ROMABLE modules that can be loaded in Deneb's Flash via Luciferin or burned into custom ROMS via Remus.
Manual for it AFAIK doesn't exist but I'll be making a guide real soon (once I figure out my A4000 now that I'm back from vacation! Hurrayz \o/)
Great Marios, thanks for that - I will try a few and see how I get on :)
I'm looking forward to seeing your new project come together.
Don't worry about Skelz, its a private joke - I was telling him to RTFM lol ;)
Steve.
First one I put in was the A1000 Jingle, then the usb device stuff
still looking forward to a tutorial Mario I`m sure I will find it very helpful and informative
I had the same question before.. AfA_OS would simply not work on my system for some reason the Morelibspace module did not seem to work from the startup sequence.
So i thought what happens if i just dump this module on the Deneb Flash? Well it works perfectly now!
So i think its just as simple as clearing the flash, remember the previous stuff that was already in flash becuz you can't add, only erase the total flash and then add all modules again together with the new file/module you want to use.
Dont exactly know how this works for example kickstart 3.9 yet, but would be aswesome if it works and we just have the single boot since deneb loads the rest :-D
Ofc it works like a charm as single boot :)
Deneb is indeed awesome and yep, I did the morelibspace thing almost 1.5 years back on my previous A4000.
Morelibspace exists as a command under C: and as a ROMable flash module under Devs: (morelibspace_module). Under Remus you NEED to use the module as it won't let you put the pure morelibspace in the kickstart. Under Deneb iirc it let you.
