Sold Oktagon 2008 rev.6 scsi controller
  • Thread starter Thread starter Exilent
  • Replies Replies 4
  • Views Views 1326
Exilent
Netherlands
Noord Brabant
Oktagon 2000 & 2008
[TABLE="class: basedata"]
[TR]
[TD]Company
BSC / Alfa Data, Germany [/TD]
[TD]Date
1991 / 1993[/TD]
[TD]Amiga
A2000, A3000, A4000
[/TD]
[TD]Interface
Zorro II
[/TD]
[TD]Autoconfig ID
2049 / 5,8
2092 / 5,8
[/TD]
[/TR]
[/TABLE]
  • SCSI 2 controller
  • NCR 53C94 @ 25 MHz
  • does not use DMA but interrupt driven programmed I/O
  • 50 pin internal SCSI connector
  • DB25 external SCSI connector for both snap-in and screw-in connectors
  • Slow Cable Mode for external devices with long cables
  • place for a 3.5" hard disk on the card
  • autoboot ROM (oktagon.device) - autobooting requires at least Kickstart 1.3
  • ROM versions less than 6.5 may have problems with removable media devices
  • the ROM uses a MOVEP operation - which is an illegal instruction on the 68060 - making troubles during bootup on 68060 systems
  • RDB compatible
  • hard disk activity LED connector
  • hard disk controller disable jumper
  • A-Max II driver
  • supported by Linux
  • Oktagon 2000 ()
  • no memory expansion
  • also called as A.L.F. 3
  • Oktagon 2008
  • sixteen ZIP sockets accept 8 MB 16 bit RAM
  • supports either static column or page mode 1M×4 ZIPs
  • accepts ZIPs in groups of four giving 2, 4, 6, 8 MB configurations
  • memory disable jumper
Asking 35 euro + postage
Untested!
Me too just in case ;)
Sent from my D5106 using Tapatalk
