SkydivinGirl
Retro Girl
Since I am no longer selling assembled SaV64s, I am selling the remaining parts I have as partial kits. These kits contain all the difficult to find and custom parts that were created for the SaV64, as well as a few common parts that I have. I am hoping that someone might want to purchase a large lot of these to build and sell assembled units but they are available for anyone to purchase. For anyone buying 5 or more partial kits, I am giving a discount on each one based upon the number purchased.
Pricing:
1 - 4 Kits : $20 Each
5 - 9 Kits : $19 Each
10 - 14 Kits : $18 Each
15 - 19 Kits : $17 Each
20 - 24 Kits : $16 Each
25 or More Kits : $15 Each
These partial kits weigh less than a completely assembled SaV64 so a single kit will cost $13.50 to ship to most countries outside the USA. Canada is less expensive. When sending a PM for a shipping quote, be sure to send along your full shipping name and address so I can give you an accurate quote. If you don't send this information then you'll just get a reply back from me asking for it.
Each partial kit contains the following:
- SaV64 Case (main case, solid end, input end, screws)
- Rubber Output Cable Strain Reliever
- LED Holder
- SaV64 PCB
- SaV64 Daughter Board PCB
- 2 x SaV64 Stickers
- SaV64 Input Description Sticker
- 6mm Heat Shrink Tubing
- Reset Switch
- 2N3906TA Transistor
- 470 OHM 1/2W Axial Resistor
Here's the remaining BOM along with the Mouser and/or Digikey numbers necessary to complete each kit.
Assembly directions are located here: http://www.lemon64.com/forum/viewtopic.php?p=711511
Thanks everyone!
Heather
Pricing:
- LED Holder
- SaV64 PCB
- Reset Switch
Code:
Qty Loc Markings Description Manufacturer # DigiKey # Mouser #
1 C1 105 CAP CER 1UF 10V 10% RADIAL FK28X5R1A105K 445-2851-ND 810-FK28X5R1A105K
2 C2,C3 104 CAP CER 0.1UF 25V 10% RADIAL FK28X7R1E104K 445-8618-ND 810-FK28X7R1E104K
1 C4 106 CAP CER 10UF 10V 10% RADIAL FK24X5R1A106K 445-8493-ND 810-FK24X5R1A106K
1 D1 DIODE GEN PURP 100V 200MA DO3 1N914 1N914FS-ND 512-1N914
2 F1 FUSE CLIP CART 250V 6.3A PCB 0751.0110 486-2019-ND 693-0751.0110
1 F1 FUSE GLASS 3.15A 125VAC 5X20MM 5TT 3.15-R 507-1565-ND 530-5TT3.15-R
2 J1/J2 CON PWR JCK 2.0 X 6.3MM HIGH CUR PJ-057AH CP-057AH-ND 490-PJ-057AH
2 J1/J2 CON PWR JCK 2.5 X 6.3MM HIGH CUR PJ-057BH CP-057BH-ND 490-PJ-057BH
1 K1 RELAY TELECOM DPDT 3A 5V 8-1393792-5 PB383-ND 655-V23105A5001A201
1 LED2 LED IND 5MM RED/GRN WHT DIFF WP59EGW 754-1232-ND 604-WP59EGW
1 R1 433 RES SMD 43K OHM 0.1% 1/10W 0805 9-1614884-5 A103208CT-ND 667-ERA-6AEB433V
1 R2 RES SMD 232K OHM 0.1% 1/4W 0805 2-2176094-8 A110770CT-ND 667-ERA-6AEB2323V
1 R3 4700 RES SMD 470 OHM 1% 1/8W 0805 RT0805FRE07470RL 603-RT0805FRE07470RL
1 R4 182 RES SMD 1.8K OHM 0.1% 1/10W 0805 6-1614884-8 A103171CT-ND 667-ERA-6AEB182V
1 R6 RES SMD 698 OHM 0.1% 1/4W 0805 2176092-4 A110528CT-ND 667-ERA-6AEB6980V
1 R7 103 RES SMD 10K OHM 0.1% 1/8W 0805 ERA-6AEB103V P10KDACT-ND 667-ERA-6AEB103V
1 U1 IC OVERVOLT PROT CTRLR SOT23-6 LTC1696ES6#TRMPBF LTC1696ES6#TRMPBFCT-ND
1 U2 OPTOISOLATR 5KV TRANSISTOR 4-SMD LTV-817S 160-1367-5-ND 859-LTV-817S
1 X1 CONN DIN 7 PIN FEMALE PCB SDS-70J CP-2370-ND 490-SDS-70J
1 X2 TERMINAL BLOCK 5.08MM 2POS PCB OSTTG025100B ED2703-ND
1 Circular DIN Connectors 7P MALE PLUG - DIN 270 NICKEL/GOLD REAN NYS323G 568-NYS323G
1 CABLE 4COND 18AWG BLACK
4 3M Rubber Bumper Pads Self Adhesive Anti Skid Feet Bumpon SJ-5007 Find on eBay
Thanks everyone!
Heather
