Pass through cable to suit Piccolo Graphics Card
davideo
I look like Gizmo
Staff member
Administrator
Staff Moderator
Treasurer
Boston, Lincs
Bumping your thread:
'Bumping' is defined as posting in your For Sale or Wanted thread for the purpose of bringing it to the top of the list of most recent threads. Unless you have made a significant change to your thread you may only bump your post once every two weeks. A significant change, refers to a price change or any other relevant information that will be important to a buyer.
As such your thread will be de-bumped
Jameson
Queensland
Lol, ok. I have a significant change to make - I have just found out that the Piccolo card uses a different pinout to other rtg cards on the Amiga such as the Picasso II etc, so the pass through cable I need MUST be the one that was supplied with the Piccolo card.
Thanks.
dw0ntU5m3
US
Michigan
Lol, ok. I have a significant change to make - I have just found out that the Piccolo card uses a different pinout to other rtg cards on the Amiga such as the Picasso II etc, so the pass through cable I need MUST be the one that was supplied with the Piccolo card. Thanks.
It's not really special it's just a 9 pin RGB (or EGA) connector. Most other Amiga RTG cards just use a 15 pin VGA connector which is more common.
Jameson
Queensland
Hi there.
Are you sure? I tried a standard VGA cable with a 15 pin to 9 pin adapter and it did not work. So, I Googled and found a thread where someone says it is not a standard pin out and that you needed the original, or correctly wired cable. :(
roy_bates
resistance is futile!
england
birmingham
i can probably make this cable if your willing to pay for it and the shipping tracked to australia.
i would need to know the length you want it as well...
i would also need to know which piccolo it is.
