Closed PC case and a midi keyboard for sale
  • Thread starter Thread starter morcar
  • Replies Replies 4
  • Views Views 1616
morcar
Wales, UK
Xclio Blackhawk PC Tower Case £51 postage included
Spec
Type Full Tower
Color Fully BLACK Finish
Case Material Chassis: 0.8mm SECC; ABS Plastic
With Power Supply No (Support up to 220mm long casing PSU)
Motherboard Compatibility Flex ATX, Micro ATX, ATX & Full ATX (12"x13")
Expansion
Internal 5.25" Drive Bays 3 or 6 bays (Smart HDD Modular System)
Internal 3.5" Drive Bays 4 or 8 bays (Smart HDD Modular System)
Expansion Slots 7
Top Panel
Top I/O Port USB2.0 x 4PCS + Audio (AC97+HD Audio) + E-SATA
Top Smart Panel Top, side & front panel fan smart controller (RPM VR, Fan on/off switch, Blue LED on/off switch)
Side Panel
Side Panel window Meshed grill
Cooling System (FAN)
Case Chassis - Front 12cm * 2PCS (Blue LED + transparent frame & blade)
Case Chassis - Side 25cm * 1PC (Blue LED + transparent frame & blade)
Case Chassis - Top 12cm * 2PCS (Blue LED + black frame & blade)
Case Chassis - Rear 12cm * 1PC (optional)
Physical Spec
Dimensions 560 x 210 x 510mm (D*W*H)
Only things that are missing with this case is 1 hard drive holder and 1 120mm blue led front fan other wise this is how i had it when i bought this case. There is no proper box but i will find one to pack it in and post to the winner.
You can see a vid of this case on the address below
http://www.youtube.com/watch?v=D7ECFKQmrLk
More pictures of this case that you will getting are here
http://s10.photobucket.com/albums/a115/pthomas1975/pc case/
Evolution MK-125 Midi Keyboard £29 postage included
I have not used this much as i have bigger keyboards so i thought someone would like ot have it and use it as it should be. A great keyboard none the less
SPECIFICATIONS
1. Keyboard : 25 standard keys (Velocity sensitive)
2. Control : Switches (WHEEL, MIDI CHANNEL, PROGRAM, MEMORY,
TRANSPOSER, OCTAVE, VEL CURVE, BANK LSB, BANK MSB,
RESET AC, GM RESET)
PITCH BEND WHEEL
MODULATION WHEEL
POWER SWITCH
Numerical Keys (0-9)
3. Display : 3 digit LED
4. Jack : DC IN (DC 9-12V), MIDI OUT, SUSTAIN
5. Dimension : 480 x 215 x 80mm (W) x (D) x (H)
6. Weight : 1.85 kg
Note : Specification are subject to change without prior notice.
for a manual you can go here
http://www.m-audio.com/images/global/manuals/mk125eng.pdf
I don`t want to seem picky but should the external ....
External 5.25" Drive Bays 3 or 6 bays (Smart HDD Modular System)
External 3.5" Drive Bays 4 or 8 bays (Smart HDD Modular System)
be internal :cool: hehehehehheheheh & Ribbits
If only I did`t have to pay the gas & electric bills, plus send my daughter on holiday for Easter I would probably have one :)
good luck though
good luck though
No probs i just sorted it out now.
If it dont sell i will pm you and once your ready or want it you can let me know.
interested
interested
interested in the Evolution MK-125 Midi Keyboard £29 postage included if still for sale:thumbsup:
my god i forgot about this thread sorry to say i think everything has been sold
