Closed PC rarest sound: Innovation SSI-2001, based on Commodore SID, replica
easy_john
Rus
Spb
Replica of rarest soundcard for PC - Innovation SSI-2001.
This card was based on Commodore SID chip.
Originally SSI-2001 supported only by 16 games http://www.mobygames.com/browse/games/dos/tic,1/ti,73/
But for now forum member Bristlehog created:
- driver for AIL/MIDPAK, AIL/32 and Miles Sound System, that means you can try to add support to many games from DOS era, for example SSI-2001 already successfully work in: Dune2, The Elder Scrolls Arena, HOMM2, Jagged Alliance, Warcraft and others.
- .midi player (PX MIDI, that based Miles Sound System)
- .sid player (required fast pc, since currently not optimized)
Replica was created by members of "vogons" and "phantom" forums, the main part is developed by Russian member Fagear.
(Board layout is self-documented, contains all information about how to solder chips https://yadi.sk/i/WCU7q5Svh89Xo )
For sale - board from last batch, with latest board revision.
Populated with SID 8580r5 with appropriative voltage regulator and capacitors and bracket.
(SID chip is socketed, but you need re-solder voltage regulator if you wish to change to earlier 6581 SID)
Tested - board and SID is fully working (tested, that SID with working filters).
Asking 150 eur.
Will list elsewhere. I can accept offers.
Will ship worldwide, with insurance and tracking.
For most EU and US shipping about 15-20 EUR, but sometimes differ, so actual shipping will be calculated when we know destination country.
@shock__
Commenting on an items worth in any form is a strict no-no on AmiBay.
Also if you have a problem with an item being listed for sale you should report the post for investigation.
@easy_john
After a lengthy discussion it has been decided that this thread should be closed.
A PM will be on its way to you shortly.
