Filled Phillips CM8833-II repair, Midlands UK
this is in for repair and service,lopt has failed and the part is on order
already replaced the mains switch(it was sketchy) and done some work on the board as it needed some attention,ill put up a couple of pics for tranparency in bit after a hot drink
second picture is just tidying up a previus repair someone did,under the lopt,first one is the rgb port
this is now fully working,ive done a soak test to amke sure all the controls and functions works as they should
ill put up some pictures in a bit.it was also a bit grubby,so i gave it a clean
excuse the mess,i moved it downstairs the room isnt used to do repairs,its basically junk storage
just popped on the forum to mention this was picked up friday 27th
Roy, I’ve been told you are THE man for monitor repairs, I have a 1084S that doesn’t switch on. Also I have a full set of caps for it which could be replaced while it’s being looked at. I can deliver and pick up.
sure,can you send me a private message
if you can let me know which 1084s it is,it doesnt matter but for service details my end,i might need to know in advance,send me a pm anyway,ill give you my address for dropooff im happy to repair it if you want
