2025-09-09 : Bumped and updated stock numbers.
Pi1541 Hat for 3A/3B €29 / $32 (1pcs available )
Pi1541 with Browser Cartridge - IEC cable included €33 / $36 (1pcs available )
Pi1541-II €45 / $49(1pcs available )
Pi1541-III €50 / $54 (1pcs available )
SD2IEC with Browser Cartridge - IEC cable and SD card included €35 / $38 (2pcs available )
SD2IEC with Epyx fastload Cartridge - IEC cable and SD card included €35 / $38 (2pcs available )
SD2IEC Userport version - IEC cable and SD card included €30 / $33 (1pcs available )
Tapecart Nano MicroSD - Sd card included €25 / $27 (1pcs available )
Tapecart Nano SD - Sd card included €25 / $27 (1pcs available )
C128 Diagnostics cartridge + Keyboard dongle ( six different selectable test programs in rom ) €23 / $25 (1pcs available )
C128D Keyboard adapter - Use C64 keyboard on a C128D €9 / $10 (1pcs available )
MegaDrive to C64 adapter €15 / $16 (1pcs available )
PadSwitcher64 - Use SNES controller on C64 - €23 / $25 (1pcs available )
MSX to Megadrive adapter - Use megadrive controller on MSX - €12 / $13 (1pcs available )
SNES to C64 / Amiga adapter - €18 / $20 (2pcs available )
SNES to MSX adapter - use snes controller on MSX - €17 / $19 (2pcs available )
3Dapter USB-C - Use SNES, NES, Megadrive controller on modern PC - includes cable €25 / $27 (2pcs available )
Gameport to USB-C Use old gameport joysticks and gamepads on modern PC - includes cable - €32 / $35(2pcs available )
The number of available is how many i have ready to ship right now, i can build more but then there will be a few days longer wait.
Tracked shipping inside EU should be about €15
Tracked shipping outside EU should be about $11
Payment can be made by IBAN transfer or by Paypal in USD or EUR.
All items will be sent as Sale of goods with correct value unless you specify otherwise.
Also check out the following threads for more C64 / Amiga related stuff:
Pistorm32, Pistorm2K, A314CP, RGBtoHDMI, Gottagofastram2000
For Sale - Pistorm32, Pistorm2K, A314CP, RGBtoHDMI, Gottagofastram2000
2025-09-09 : Bumped and updated stock numbers. These items have been built by myself and are fully tested before shipping. Pistorm32 WHITE with white edge connector - €75 / $79 ( 2pcs available ) Pistorm32 RED with black edge connector - €75 / $79 ( 1pcs available ) ( I can make any...
www.amibay.com
RIPPLE IDE, RGB2VGA Ultimate, PSX2AMIGA
For Sale - RIPPLE IDE, RGB2VGA Ultimate, PSX2AMIGA
2025-09-09 : Bumped and updated stock numbers. These items have been built by myself and are fully tested before shipping. Ripple IDE controller for A2000 / A3000 / A4000 by LIV2 - Gold plated edge connector - €56 / $59 ( 2pcs available ) OpenPSX2AMIGA - Use PS1 or PS2 controllers on your...
www.amibay.com
These items are all made by me and tested before shipping.
The designs are all open source and can be found here :
GitHub - tebl/C64-Pi1541-III: I wanted a Pi1541-module that did not feel like I was handling bare electronics, so I made another that manages to hide most of the scary bits without needing a 3d-printer.
I wanted a Pi1541-module that did not feel like I was handling bare electronics, so I made another that manages to hide most of the scary bits without needing a 3d-printer. - tebl/C64-Pi1541-III
GitHub - tebl/C64-Pi1541-II: I wanted a Pi1541 module that did not feel like I was handling bare electronics, so I made one that hides most of the scary bits (no 3d-printer required).
I wanted a Pi1541 module that did not feel like I was handling bare electronics, so I made one that hides most of the scary bits (no 3d-printer required). - tebl/C64-Pi1541-II
GitHub - tebl/C64-Pi1541-Module: I wanted an alternative to the SD2IEC on my Commodore 64, and I almost instantly took a liking to Pi1541 software. I did however need to design a board for it and this was the end result - even includes beepers, OLEDs
I wanted an alternative to the SD2IEC on my Commodore 64, and I almost instantly took a liking to Pi1541 software. I did however need to design a board for it and this was the end result - even inc...
GitHub - tebl/MSX-Mega-Adapter: Adapter so that Sega Mega Drive (Sega Genesis in North America) gamepads can safely be used with the MSX line of computers.
Adapter so that Sega Mega Drive (Sega Genesis in North America) gamepads can safely be used with the MSX line of computers. - tebl/MSX-Mega-Adapter
GitHub - Hojo-Norem/PadSwitcher64: Interface to allow Super Nintendo (SNES) control pads to be plugged into a C64's joystick ports.
Interface to allow Super Nintendo (SNES) control pads to be plugged into a C64's joystick ports. - Hojo-Norem/PadSwitcher64
COMMODORE 128 DIAGNOSTIC REV.785260 KEYBOARD DONGLE - Share Project - PCBWay
COMMODORE 128 DIAGNOSTIC REV.785260 KEYBOARD DONGLE This is a Commodore C128, C128D, C128DCR 785260 Diagnostic Keyboard Dongle Hello,This is a Commodore C128, C128D, C128DCR 785260 Diagnostic Keyboard...
www.pcbway.com
(DIY) COMMODORE 128 ROM CARTRIDGE (32KB & 16KB) - Share Project - PCBWay
(DIY) COMMODORE 128 ROM CARTRIDGE(32KB & 16KB)This is a Simple ROM Cartrridge for Commodore C128, C128D, C128DCR.Cartridge's ROM capacity is; 2x32KB (64KB) and 4x16KB (64KB)Hello,This is a tested ...
www.pcbway.com
TAPECART MICRO-SD NANO is an Easy to Use Commodore 64 SD Card Loader. - Share Project - PCBWay
Commodore Tapecart Micro-SDHello, This is a tested and working project.COMMODORE Tapecart MICRO-SD NANO is an Easy DIY project, all components are through hole, marked on the PCB, Easy to solder, Easy...
www.pcbway.com
TAPECART SD NANO is an Easy to Use Commodore 64 SD Card Loader. - Share Project - PCBWay
Commodore Tapecart SDHello, This is a tested and working project.COMMODORE Tapecart SD NANO is an Easy DIY project, all components are through hole, marked on the PCB, Easy to solder, Easy to make ;)T...
www.pcbway.com
COMMODORE-64 Pi1541 FDD EMULATOR with TURBO FILE BROWSER CARTRIDGE - Share Project - PCBWay
COMMODORE-64 Pi1541 FDD EMULATOR with TURBO FILE BROWSER CARTRIDGEHello, This is a tested and working project.COMMODORE-64 Pi1541 ZERO FDD EMULATOR with TURBO FILE BROWSER Cartridge is an Easy DIY pro...
www.pcbway.com
SD2iEC (COMMODORE 64 DISK DRIVE EMULATOR) POWERED from USER PORT (MICRO-SD VERSION) - Share Project - PCBWay
Hello, This is a tested and working project. (Tested on Commodore 64 and Commodore VIC-20)This is an Easy DIY project, components are through hole, marked on the PCB, Easy to solder, Easy to make ;)T...
www.pcbway.com
SD2iEC with BROWSER CARTRIDGE (MICRO-SD) for COMMODORE 64 - Share Project - PCBWay
SD2iEC with BROWSER CARTRIDGE (MICRO-SD VERSION) for COMMODORE 64SD2iEC (Commodore 64 disk drive emulator) with File Browser Software in Cartridge. It is for loading games/programs easier and faster.H...
www.pcbway.com
