I just bought a 2MB Picasso II for my A2000 Rev4.4. Hopefully will receive it soon.
At the moment My A2000 only has the stock 68000 and 1MB Chip and GVP Impact SCSI with 8MB Fast ram.
I am making a deal where i should soon be getting an A2630 '030 accelerator with i think 2MB 32 bit fast ram.
My question is this. When I had my A4000T with 68060 and Picasso IV i used to have it with 800x600 resolution @ 24bit (16 million colors) and yet with the built in flickerfixer i could run normal native PAL stuff like my favorite games through WhdLoad on the same monitor.
The Picasso II if i'm correct has got a pass through and built in switch for native resolution.
If i buy this flickerfixer solution https://www.amibay.com/showthread.php?t=20468 which looks cheap and very good, would I be able to use it along with the Picasso II so that i can have P96 Modes and native modes using the same LCD VGA monitor ?
Also, I know i have to reduce the ZII fast ram to 6MB because of the 2MB of the Picasso II. I will (if i get the A2630) be compensated by the 32bit fast ram.
Till then will the 68000 + 6MB fast ram + Picasso II be able to handle 800x600 @ say 16bit or even 24bit and still work smoothly ?
What about with the A2630 '030 @ 25Mhz + 2MB 32bit fast ram?
Also first question about that flicker fixer being interfaced with the Picasso II is pretty important?
Thanks a lot guys
Thanks a lot guys
