Low Profile PiStorm (classic) Adapter board that connects a Raspberry Pi to the Amiga's 68000 socket or a socket adapter on the A2000
$40 plus shipping
I have two of these. 2 of 4 sold 4/8/2024
What you will need (not included):
$40 plus shipping
- Low profile round machined 68k socket pins
- High-quality Samsung CAPs
- Brilliant Commodore Blue PCB
- Pre-flashed (with longer hold flash) and tested working
- Tested with ZZ9 PiStorm testing board and buptest
- allows hard drive files/file sharing with the Pi's SD card
- the Pi can act as a graphics card for the classic system
- the Pi can provide CPU-addressed memory for a significant memory boost
- the classic machine can use the Pi's network adapter for access to the internet or local LAN
- the Pi can capture the keyboard and mouse for use on the classic system
- Raspberry Pi (best will be the 3 A or B)
- A memory card for the Pi and the Amiga as storage
- Firmware software, there are several available for download depending on taste and how much setup you want to do on the Amiga side
- Emu68, Musashi/Linux, CaffineOS, AmiKit to name a few
- Anything you want to plug into the Pi, such as an HDMI cable for Amiga Pi RTG and/or Pi setup.
- Consideration for space inside the machine, for instance on the A2000 you can use a CPU slot to socket adapter board. On the A500 you may need to cover the metal shield with tape or something to ensure it doesn't touch the Pi
