PiStorm32 lite Adapter board that connects a Raspberry Pi to the A1200 trap door slot
Ships from the USA so if you are in the USA it will be faster ship times and tariff are already paid for. Also, the price does reflect the tariffs, I wish I could lower the price.
I have 1 more (out of 5) of these and I am asking 100 USD per board + shipping
Are you ready for some modern features and performance on you're Amiga 1200? The Raspberry Pi board will emulate a 68000-68040 CPU with a huge boost speed. Active support channel on Discord.
NOTE: The Raspberry Pi is not included, the below information is provided to show some features that the Raspberry Pi can provide a classic computer when attached to this board and plugged into a classic computer (also not provided).
Look for my pre-Install Raspberry Pi with SD Card service in our other listing if you need a Raspberry Pi.
Retro Pre-Installed Raspberry Pi with SD Card | eBay
Additional features of a Raspberry Pi plugged into this board and installed in A1200
- allows hard drive files/file sharing with the Pi's SD card
- the Pi can act as a graphics card for the classic system
- the Pi can provide CPU-addressed memory for a significant memory boost
- the classic machine can use the Pi's network adapter for access to the internet or local LAN
- A1200 trap door slot edge connector
- 40 pin connector to connect the Raspberry Pi
- High-quality Samsung CAPs
- Brilliant Commodore Blue PCB
- Coolant pad on the back
- Raspberry Pi (best will be the 4 B, 3 A or B)
- A memory card for the Pi and the classic system storage
- Firmware software, there are several available for download depending on taste and how much setup you want to do on the Amiga side
- Emu68, Musashi/Raspberry Pi OS, CaffineOS, AmiKit to name a few. Google search or the discord channel can help you locate this.
- Anything you want to plug into the Pi, such as an HDMI cable for Amiga Pi RTG and/or Pi setup.
- Optional: Spacers / standoffs for your Raspberry Pi
