Playing Audio CD's from the SCSI bus?
merlinkv
Ukraine
Kyiv
Hi
I have a CS MK-II with SCSI kit.
At the SCSI bus I have two SCSI DVD-RW Drives.
It's possible to play Audio CD's from the SCSI bus? or only from the audio output of the drives?
Zetr0
Ya' Like it Retr0?
Yes and yes
List of CDDA music Players
most will only need a <nameof.device> and a <unit number> to work - I beleive that even Make CD can read audio data via the <.device> bus too =)
merlinkv
Ukraine
Kyiv
@Zetr0
I will test now....
Thanks a lot
---------- Post added at 10:00 ---------- Previous post was at 09:00 ----------
@Zetr0
- PlayCDDA Gui ask about "openpci.library 1" and don't start. I have installed openpci.library 2.0 and also tested with 2.1. No way.
- MakeCD Play Audio tracks. Works 100%
Any idea for PlayCDDA?
cosmicfrog
The 1 That Ribbits
Leek, Staffordshire Moorlands
indeed I always wondered why cds/dvds came with a 4 wire audio out when we send everything over the bus ;)
snoopdos time
merlinkv
Ukraine
Kyiv
@cosmicfrog
Of course, I know.
I have one DVD connected to the Audio connector of my A4000D mobo.
But I'm interested to play all from the SCSI directly.
MakeCD works fine. But don't have a good Gui to play CD's (or maybe I don't know, is my first time testing MakeCD).
Zetr0
Ya' Like it Retr0?
@merlinkv
try the playCD that comes with IDEFix97 - that I find works well -
also there is a PlayCD program with AmiCDFS240
that should get you sorted my friend =)
merlinkv
Ukraine
Kyiv
@Zetr0
I have installed the AllegroCDFS comes with my FastATA MK-V
So, I installed IDE-Fix 97 everything seems to be OK but PlayCD cames with IDE-Fix all time says a "Play Error"
Of course I changed the MountLists and I try using the ML generated by IDE-Fix.
PlayCD of IDF recognizes fine the Audio CD, tracks, playing time..... But not play CD's
MakeCD continues playing 100%
Zetr0
Ya' Like it Retr0?
personally I would drop the AllegroCDFS to be honest - I had nothing but trouble with it on my A1200 via native IDE or FastATA - ghastly program.
I shall try and get a play with the PlayCD (from IDEFix) with my SCSI on my A2000 see if I can get any joy.
In regards to PlayCD of IDF - is it trying pull the audio data down the SCSI bus or is it playing it from the audio out on the Optical Drive?
Its obviously possible that it can be jigged to work as MakeCD works perfectly.... hmmm I shall ponder this.
merlinkv
Ukraine
Kyiv
@Zetr0
All time I'm testing only from the SCSI bus.
I have one problem with IDE-Fix. After installation HDToolBox hungs the System.
Maybe a conflict with the FastATA drivers? I'm very happy with the FastATA, of course is a PIO board (not a DMA), but drives works fast at PIO4.
I will try again....., and again......
merlinkv
Ukraine
Kyiv
Well,
Solved the issues with FastATA & IDE-Fix drivers, both coexists now without conflicts. :)
I found another way to play from SCSI bus.......
Installing the CDDA-FileSystem (Aminet) and making a separate Mountlist for each drive (only mounted when needed), the AmigaOS recognizes each track like an .iff file. So, it's possible to play directly from AMPlifier & other players.
I maked all tests without any audio cable connected on the drives.
.IFF and .WAV is almost the same, what really changes is the first four bytes of the archive (IFF instead WAV).
merlinkv
Ukraine
Kyiv
@rkauer
Yes, quality is the same. And the CDDA-Filesystem is a good solution to use different players and make playlists.
But really, I don´t know for what reason the PlayCD from Aminet (with IDE-Fix 97 installed & CacheCDFS configured as "SCSI direct") don´t play from SCSI bus. All times "Play Error" or "Track Error".
In standard configuration, MakeCD play from the SCSI bus without any problem.
